If anyone can help will be much appreciated.
Here are the two stock files I've dumped from my '22, before and after (-HC) an FDRS PCM update last year. Manufacture date March or April 2022. Both include the parking brake 'fix' from Ford.
Thank you.
Can you see the where the parking brake "fix" is at in the tune?
Not that I've seen. I'm guessing because it's a recall/"safety feature", tuners are reluctant to search for or expose the mechanism.
I'm thinking about designing a mod for this "fix" whereby a microcontroller sniffs the CAN communication for a command to shift P -> D or P -> R, then injects a parking brake release event for the ABS.
I kind of like the automatic engagement part because it unloads the transmission pawl.
