VAP Tune- and no, I'm not sharing it...
I recently gave up on trying to figure out how to tune my F-Type R and purchased VAP's tune with pulley upgrades. I accidentally ordered the wrong bottom pulley, so all I have right now installed is the top pulley and the tune itself. I spoke with the guy who wrote the tune and he said it was fine to run it this way with the tune as-is until the bottom pulley arrives.
First, VAP says, and I agree, that many parameters that VAP changes to increase power are missing with HP tuners. However, there are quite a few important parameters available for tuning with HP tuners that would be helpful. I can't show you my tune. Truth be told, I paid a lot of money for it, so I'm not really willing to just give that away anyway- but if I did, I could get sued. So don't ask. The answer is no- sorry.
That being said, it is pretty obvious what Jaguar does to these engines when they put them in different cars with different HP numbers. This engine, no matter what car it's in, is capable of at least 600hp (crank). Looking at the VAP tune, all they really do is raise the limits on the higher RPM bands for your primary tables like boost limits, driver demand, torque control, and fuel parameters (for the most part). Jaguar (and Land Rover) simply retard the top RPM bands to whatever degree they need with all of these parameters. VAP uses WinOSC to do their tuning- I think he said he does over 90 tables in WinOSC for their tune (which is interesting because I count 91 tables in HPTuners that have been changed..). The pops and bangs mod VAP does is not in HPTuners (he told me how he does it), so I'm guessing when he says 90 tables, he's counting the group of tables as one table instead of six. HPTuners needs to add a lot of points in their poling before it will equal WinOSC. I'm not sure why they didn't- the Fords that use this ECU all have MANY more points than the Jag/LR list of points. I wish they would at least try to make the tunable list more complete.
My point of the post is, I do think you could use HPTuners to unlock much of the potential of this engine if you know what you are doing (which I do not...). I still think there is some locked-up power left to get even with my VAP tune- timing, for example, is still only 25.5 degrees WOT at 6000 RPM, and I know of a couple people that run 27 degrees of timing for maximum power on 93 octane. VAP can't sell a tune that will blow up your car, so I think I can push it just a little bit more here and there if I wanted to. Keep in mind, though, that there are 90+ tables to look at before you are going to get anything close to a VAP tune. But it's doable to a high degree.
