6L80E Terminator X MAX and TUTD
Has anyone on here used the terminator Max to run a holley with a 6L80E? I have one that is working for the last 6 months, The customer wanted to add TUTD to it and the different modes. I added a shift handle, and on the Holley it is showing that the TUTD buttons work, and that the Secondary shift mode are activating. However when I am in the transmission (via HP) it doesn't seem to be responding to these things.
I have referenced many other TUTD threads, which got me as close as I have been. I can get the transmission into TUTD mode by having the selector in D5. However nothing happens when I actually use the buttons. Same with the mode switch, it doesn't switch from normal to tow/haul or anything like that, NO changes in shifting behavior etc.
I am at a bit of a loss, I assume the serial message is being sent but something isn't happy on the TCU side. I am running out of ideas, and since I am not using the Superchips transmission hand held Holley isn't any help.
One last thing I plan to try is to flash the TCU with the handheld and see if the tap up tap down starts working somehow.
