Hi, i use bullydog GT , i will maybe ditch it for a HPtuner but i need know , if i can play with the shift point on my 48RE? Or this option are no available now? Thanks
Yes you can adjust the shift points but you need to move the anti gear hunt parameters out of the way
Hey I don't mean to hijack this thread but are you the same gentleman that wrote a tune for 6.7 into a 5.9 truck with 5.9 ecm? Could use your help if so. I don't see a way to private message here
Yes I did write a tune for a 2005 with a 6.7 engine running on a 5.9 ecm
Can you write tunes for efi live also? For a 2006 ram 3500 with a 6.7? Or just for hp tuners. I have an early 04 that I plan on swapping a 6.7. Do you tune with 6.7 injectors or 03-04.
Thanks. And how much for the tunes?
It’s been absolutely ages since I touched anything 5.9L and 48RE related so I’m pretty out of touch on what I used to do with them, I’ve really only been focused on the 2010+ and lately it’s been far more code related stuff in the 2010+ where I’ve had a lot of my focus.
