Hey everyone, first post!
I have been battling an issue with my Jeep for a long time now, where during a WOT pull i 90% of the time get a STFT between 0-4.7% on bank 1 and bank 2. when at 0% STFT i hit 12.7AFR, right where I want it.
Every time this happens it goes to the rich side, sometimes to around 11.6-11.8 AFR.
here is the build -
2010 Jeep Commander 2wd
SBE 5.7
Custom grind texas speed cam - 224/234 0.602/0.597 113 LSA
6.4 car intake
long tube headers
3 inch catless mids
3 inch dual catback, x pipe
8hp70 swap
Edge racing 3400 stall
custom CAI
93 octane
Things i have done to try correcting this -
- perfecting my VE with multiple long drives. I believe it is in great condition.
- making ECT rear for o2 sensors to 370 degrees
- changing enable delay for rear o2 to max value
- changing power enrich WOT threshold a few times between 2.19v to 3.19v (same with pedal WOT request in torque management)
- changing VE limits to be higher (165% or so)
- changed catalyst protection temps up and down without any success
I am sure there are other things i have tried, but nothing has effected this at ALL. from all i know, B1S1 and B2S1 control air.fuel at part throttle until the cutoff point driven by power enrich WOT threshold, so i should have ZERO fuel trims effecting WOT.
asking some better tuning friends indicated that the only driver here can be the rear o2's controlling fuel trim for component protection.
what am I missing?
Log and current tune attached.
Attachment 150947Attachment 150948
