Are there additional timing modifier tables not defined in HPT?
On a WOT pull it?s calling for -20 degrees of timing but all the timing tables show -10 in that area it should be operating in.
Yes, multiple
Are they accessible via UDP?
I appreciate any help you can give me.
1, you are not looking at the correct tables, 2 the multiplyer for timing in incorect in hpt for a 6.4, the vcm scanner shows the correct timing value
Is there a way to access these timing modifier tables?
I will pay $$$ to anyone that can help me out with this.
there is no timing modifier table, the conversion for the timing maps is incorrect, the timing shown on vcm scanner is btdc and it is correct.
