Hi,
I have 2015 Charger Scat Pack. During WOT it goes lean (actually it goes not rich enough) and on the dyno I can see that once it reaches 5700rpm the power is not increasing anymore:
Attachment 151217
Lambda commanded is 0.84 and at WOT car is unable to reach commanded AFR.
I checked the fuel pressure - not dropping, stable 60 psi during the pull.
During a pull I can see that injector pulse width reaches 80% at 5700RPM and that is its max. On higher RPMs it is not commanding more fuel, because it is already at 80%. Puls width is 17ms.
Attachment 151216
Question is : is it the maximum for these injectors? I know people say 80% is max healthy duty cycle, but is it possible that stock injectors are at its maximum in this carwith those mods? Car has long tube headers and removed all mufflers, JTL cold air intake.
Also is there a table in the tune that blocks the duty cycle to 80% ?
tune and log attached.
Attachment 151218
Attachment 151219
