Symptoms like missfire, but it is not...
Hi, Running a L77 with a mild cam, E38, cool air intake and in SD mode only (MAF disabled).
I have this annoying issue that I cannot figure out what is causing it :banghead: It feels like a Miss-fire on ALL cylinders when driving but no DTC is set at all (had real Miss-fire before so DTC is working), it happens very seldom but last time when driving I caught 2 occasions of this "jerk":
11.12.675 & 13.07.963 min into the log file both Cylinder Air and Instantaneous Fuel zeros out for ~100ms, then coming back to normal again. Physical sensor values seems OK (MAP, MAF, Temp, E38 Voltage etc). The car jerked big time and then continued as nothing happened.
20.24.846 & 20.32.503 min into the log file I have the opposite behavioral, fuel and air goes way high for ~100ms without any obvious reason.. Cannot recall noticing this when I drove however...
Been studying the logs back and forth and the only thing I can think of causing this jerking is a SW bug, Watchdog timeout or other SW based issue in the E38 but I can be wrong.. Any other that has experienced similar behavioral or has a clue what it could be??
