C6 TT Tuning Issue - High RPM Missfire Question
I have recently begun tuning my APS TT C6. I have 60 Lb injectors, the MSD boost a pump, and an LC1 Wideband (which I am 99% sure is calibrated correctly). I have put the car in open loop.
If you look at the following tuning logs, you'll see areas where the TPS% is greater than 80%. Before the missfire, the car is getting plenty of fuel (AFR is in the 10.5:1 range). My problem is that once the car starts to spool up, it feels like I'm hitting the rev limiter (you can verify this with the lean spikes that occur at the end of the pulls). I am unsure as to what the issue is....ANY help would be appreciated.
Please click on the following link for my edit file, sanner config, and scan file.
www.nd.edu/~caschenb/tt_vette
Thanks :chug:
