6l80e case connector wiring
Afternoon i have a 2017 chevrolet truck 5.3v8 and a 6l80e transmission ! The problem is the wiring for the case connector on the transmission had melted on the exhaust system and i needed to replace the case connector with the pigtail i got all the wires back in except for pins 10,11 13,14 those are for the can buss which both sets have a blue wire and a white wire pins 10 & 11 10 is can high and pin 11 is can low on pins 13 & 14 are the same except that it is reversed pin 13 is can low and 14 is can high. Ok how do i determine which is can high and can low ? So i can install it in the proper hole ?
Ted
