2 Attachment(s)
p01 lm7 to l33 sd d1sc wont idle after swap
over the weekend i swapped out my lm7 for an l33 and can't get it to idle. the lm7 was bone stock with d1sc Procharger, Holley Hiram, 102tb, decapped injectors, 4l80e with circle d 2800 stall converter, and speed density tune. running driving no real problems for over a year, only swapped because i blew a head gasket after over heating in burn out event. i transferred everything over to the l33 along with adding a chopacobra cam. now the truck wont idle i have tried bumping up base idle and base rung air flow along with leaning out the ve table in idle area with no change. it does run if i hold the gas i can even hold a 700 rpm, but the sec i let go it dies doesn't even try to catch it self. unfortunately i didn't save the tune messing with it but i do have the last tune from before the motor swap. it doesn't seem to respond to any the changes i make acts the same every time. thanks in advance any help is appreciated here isAttachment 152296Attachment 152297 the tune a long
