6r80 differences and PCM logic
Hello, I'm somewhat new to tuning, and am working on that. I wanted to see if anyone could help me clarify a few things since I am planning a project. The 09-10 6r80 i am to understand is different than the 11+ models, mainly due to the lead frame having a TCM of some kind built into it. Is this the only difference? I ask because I have heard adding things like select shift to the 09-10 isn't possible. However, I have a 2010 f150, and a spare drivetrain with PCM for a 2014 (both are raptor 6.2). Both PCM's are copperhead 2048 units, so I'm thinking they are the same but just have different OS's? What I'm getting at is, if I use a 14 lead frame, put it in my 2010, re-pin the trans and PCM connectors to match 2014 wiring, then either write entire over the 2010 PCM with the OS from the 2014 (I own licenses for both), would I then be able to add paddle shifters and use select shift?
