2 Attachment(s)
6l80 experts.. have some issues..
I have been reading through the forums and seen alot of post you guys have been able to help some guys out with their trans shift issues.. ive been messing with mine for quite some time and still cant figure out what some of the tables adjust at different points in the shift process.. and different temps.
i have a 2009 silverado with a 6.0L with LSA supercharger 10lbs of boost, ls9 cam, IDX1050 inj, walbro 540 pump, flex fuel sensor, 1 3/4 LT headers w/o cats, 6L80 transmission with a transgo TOW&PRO Reprogramming Kit and sonnax valve body kit, ZL1 camaro converter. 3.42 rear gears.
But the issue im having is, on low speed turning onto neiborhood streets and such 12-15 miles per hours the truck feels like it wants to die... looks like timing drops out -17, -19 degrees on that 1-2 shift.. the next issue i have is the 2-3 shift at WOT shifts so hard that it feels like the transmission is coming throught the floor.. id love a firm quick shift at wot without breaking the tires loose or breaking the transmission..lol. just want more seamless if it possible.
if i increase the torque model everything gets worse, starts breaking tires loose at PT shifts and i cant go WOT for fear of breaking everything..
in the current tune.. it feels like the PT and WOT shifts, feel like double shift/delayed or a bad transmission mount.. "all mounts are new" and double checked..
but no matter what i try it affects the part throttle shifts as well.. to hard or too soft. i cant seem to find the in between id like.
here is a log and the events
thank you for your time, Eric
Attachment 152742
Attachment 152743
