Throttle body orientation
Hi!
Upgrading my already LS swapped 1992 camaro from LM7 / 4L60E to LQ4 / 4L80E. Since lm7 was DBC, I was able to keep the truck intake and had just enough clearance to close the hood. Now LQ4 has a DBW, the TB itself is little higher and cant close hood anymore. Thinking about making a spacer/adapter to turn TB 180deg, upside down. Would be there any issues in engine performance? I have seen some pics procharged Ls engines, with TB-s upside down...
I know the right way to go would be ls1 intake and re-routing cooling and front accessories, but since i have all perfect set-up from LM7, then I would like to keep it. And also here in Europe it is not so easy to find LS engine parts, so its also all about budget :)
