2 Attachment(s)
LMM tuning help
Hello hp tuning people, need help with my 08 Sierra LMM originally i was having a EGR insufficient code P0401 i was able to turn that off and i drove the truck for about a month and maybe 700-800 miles and now recently the truck is in Engine power reduce and also states cleaning exhaust filter. I have no codes at all with HP tuners and also with TECH2 i have no codes i cant seem to find what is going on. I was wondering if anyone is willing to look over the file and see if you can see something iam missing or that is incorrect i would appreciate it !!Attachment 153412Attachment 153413
Re-enable EGR. Do an EGR cleaning in the Tech2 function menu. Verify you have no CAI leaks (unmetered air). Check boost pressure against Baro pressure with KOEO.
you have a problem with emissions
in your file someone unsuccessfully tried to disable dpf and egr
with the related fault codes disabled
