A few questions about Mustang gt 10 speed trans.
The trans/car with 13000kms on it (I bought used from dealer) I believe overall works/operates as it should I think.
It's been into the dealer and the fluid level checked and they did a reflash and their trans guy drove the car during the initial relearn so likely as good as it can be.
The reason I had the dealer look into it was that I felt with as gentle and smooth as it is in "D" the difference in "S" seemed like the shifts were too harsh with the shifter back in sport "S" position.
After all the reflash and what not it is still the same good and smooth in "D" but although a bit better in "S" but still a bit harsher than ideal.
So question is could the S position be made a ways less angry to be only a bit more aggressive than D or could D be adjusted to be a bit more sporty feeling with a little less throttle required to downshift a gear or 2 and perhaps not skip 2nd gear from a stop.
The best combo I've found is shifter in sport and cluster in S+.
Makes for gentler shifts and more responsive to downshirts.
Wondering is its worth it to go down the road and get HP interface?
Sorry for the long post but I'd like to know a bit more about the trans.
Thx,
D
