4 Attachment(s)
3.0 explorer ST Looking for some calibration Help
Hello everyone,
im working with a 22 Explorer ST that i purchased, I've been searching the forums, and on other sites, so that i can wrap my head around HPTuners and how ford designed these PCMs to work.
my Explorer is 100% stock, I've been messing with tune for a few weeks, trying out different methods, seeing what works best. After a few iterations later, i found myself more inclined to tune this with some limiters intact to aid me incase i goof it up and send the rods to space X.
Now on to the good stuff, I'm trying to get my desired turbo airflow up, I've tried messing with Outlet pressure table, raising desired TIP, Etc. i haven't been able too get passed 31 Lbs\M of desired airflow, yet my actual will climb to 41-42 Lbs/M on the top end, i just want to be able to get them to match, preferably keep my actual turbo airflow up and not have to bring it back down to match desired.
another thing ive ran into is turbo FMEM limiters and wastegate limiter, i've tried playing with overspeed limits, requesting more from ECM 3630 airflow limit and ECM 3631 wastegate limit, ive tried raising them to the cap and or going up 10% at a time, i must not completely understand how these limits work or maybe im just missing something here..
how can i get past these turbo airflow limits? i dont want to completely disable them if i dont have to, also how can i request more desired turbo airflow?
also my spark advance stays between map point 7, 8 , 9, mostly on boarderline, but the timing is all over the place, going from 2.0 to 5.0 back to 2.0 during a pull, i can only assume the ecu puling and adding timing to keep torque under control in conjunction with the throttle plate... do i need to wait for my KOM to hit 1.0 for spark advance to settle? i know i get "popcorn" and combustibility limit, which all that i can fix. just want some more info on how i can get my desired vs actuals all to line up.
im not trying to achieve a certain psi out of these turbos, well atleast not yet...
stock explorer ST
fuel:91 (eventually e50)
4500ft of elevation
5500+ DA 2500ft DA lowest
attached is my most recent map and logs, ive seen way to may post about people logging way to much channels so ive did two seperate pulls, 2nd to 3rd, one logging sources, spark etc. the other logging what the ecm is doing with the wastegates etc.
i will appreciate any help and pointers that i get, to help me understand these PCM better.
