2 Attachment(s)
2017 F250 high boost, can you look at log and tune?
Customer has 2017 F250 that is running more boost than he remembers. I data logged the truck and the MAP pegs (or is unbelievably steady) at 255 kPa , dash display shows 2/3 the way to 40 psi. I've tuned 50+ gas cars with HPT but just starting to play with diesels. I have a stock 2017 F250 file to compare it with. If I swap the airflow>pressure control> boost limit and compressor 1 limits back to stock, will that give me stock boost pressures? Is 255 kPa the limit of the stock MAP sensor? And an overall opinion of this tune would be great also
Attachment 154353
Attachment 154354
