5 Attachment(s)
Confused on fueling for e85 and boost
This is a street driven truck lq4 forged rotating assm, s475, deka80, walbro 525 pump, 10an fuel lines, p59, flex fuel sensor, aem wideband signal being sent to pcm via ac pressure sensor wire.
Does the pcm add/interpolate fuel when in boost (Open loop) based on e85 percentage? Or does it strictly use the VE table?
Do I need to adjust my VE table to get my afr correct. Currently at 18lbs of boost, the afr is 13.7 according to the gauge.
Thank you for your time!
