1 Attachment(s)
Get a grip on falling boost pressure EA888
Hello,
before I continue looking for the error, I'll write it here briefly:worship:.
I've run about 20 tests and just can't get the problem under control, no matter what I adjust. I suspect that I simply haven't found the limiting parameter yet.
I can't get a grip on the boost pressure offset. The boost pressure drops down from ~2,500rpm by ~70kpa although I would like to keep it there.
why does the boost pressure always drop?i can't find the cause.
thank you Tim
Attachment 154634
