Explain Each DTC State (GM)
I can't find any detailed documentation for what VCM Editor is doing with the following settings, as selectable under the DTC table in GM ECUs.
disabled
misfire detest (mil blink)
misfire detect (mil on x cycles)
mil on (x cycles)
mil on (after 5 seconds)
mil off (stored fault)
mil off (remove after x cycles)
fault with service-tester
misfire detect (mil, no blink)
fuel supply system
drivebility fault (non emiss.)
drivebility fault (emiss.)
From what I can find all of the above are setting masks in the ECU for the DTC only, and doing nothing else.
I come from a Network engineering background, in any technical document next to each option is a technical description of what that is doing. Example "selecting "ramastat on" enables voltage output on the ramastat trigger wire, engaging the ramastat. Selecting "ramastat off" prevents this operation".
HPT Documentation has this same type of explanation for only some of these options, but it does not cover all of them.
https://www.hptuners.com/help/VCM-Ed..._dtc_lists.htm
Can somebody explain what the below are?
fuel supply system
Thanks.
