Gen 4 swap into 88 Wagoneer speed sensor/shift help
Not sure where to post this or if it's even allowed but figured I'd try some help here over the weekend, thank you!!
Hey everyone, just finished an LS swap Gen4 08 5.3/4L60e using original NP229 from 88 Grand Wagoneer
I'm using the Dakota Digital Pass through 8000PPM generator (sen-01-4160) through the speedometer cable to generate speed sensor signal since the NP229 doesn't have a speed sensor.
This creates a 8000 PPM signal
I bought the Dakota Digital SGI-100BT which now takes that 8000 PPM signal and turns it into 126000 PPM for GM LS ECUs that they require.
My tuning guy also updated the E38 ECU with the Tire height and gear ratio (he did not do the Trans ECU just the E38)
The Jeep is driving and idles fine, shifts out of first too early most of the time, but shifts great otherwise, upshifts are good and will wind out the gear if I hold it down.
Problem: NO downshifts while cruising weather part throttle or full throttle??!! IT just takes off in that current gear (which is OD) cause i can manually drop it into 3rd and notice the difference right away.
I've adjusted/calibrated the SGI-100bt signal while driving to match the actual speedometer speed/GPS speed and that didn't help any at all. (my scantool was reading the trans mph speed at 74mph when the actual vehicle speed was 50mph, so this is now fixed and both reading together).
Anyone can help figure out what to do from here? Is this a HPTuning issue now or anyone know if there's more to do with this SGI-100bt unit to make all this work properly. Dakota Digital Tech guy was of no help at all other than telling me it's not going to work even though they sold me the products lol (morons).
Thank you to anyone for help..
