Can you force E90 / E93 computer into maf only mode?
Curious if I can put a 2020 truck in maf only mode for airflow calculations. Started off as a Lingenfelter 2650 truck, now it has alot more items including a cam. Lingenfelter loads their tune onto the ecm with you sending it in and they have no way to send their tune for me to load per my convo with them. HpTuners downloads the stock GM file, so it's a start from scratch thing, but Lingenfelter has a bunch of other stuff on this vehicle so I believe their actual coding could be different. I'm getting a max throttle command with only 20% pedal which is clearly wrong. I've tuned plenty of the trucks without issue and this is the first to have a problem.
Anyone done
