2 Attachment(s)
Help With Tuning, novice here
Combo and a little background: 07 Trailblazer SS, aluminum 6.0, stage 2 cam, specs unknown but imagine around 224,228 @ .580, Long tube headers, full stainless exhaust all the way out the back with 2 small cats (aftermarket system installed by someone else), front 02's are 6 to 8" from collectors, rears are turned off in tune. Truck showed up with exhaust leaks everywhere and bad 02's. Front 02's replaced with bosch, exhaust system was taken apart and all leaks fixed. new tr55 plugs, msd wires, all coils were replaced with another set of oem coils.
I am not a stock ecu tuner at all, I know just enough to get myself into trouble. I do however tune holley, fueltech etc. so Im not totally illiterate on the subject. I have a guy that put a tune on the ecu but has since flaked on me.
Problem: truck runs fine and 02's are even at .400 or so when cold. Once running a couple of minutes I believe its entering into closed loop and both 02's start fluctuating from 900 to 40s causing short and long term fuel trims to swing from dead lean to rich. Attached are log of the problem and tune, any help of course is appreciated. Lol, winner will be compensated.
Attachment 155279Attachment 155280
