3.5 Ecoboost swap without a spark
I swapped a '17 3.5/6R80 out of an Expedition (Gen 1 still) into a 2001 Reg cab 4x4 truck. I had a guy do the harness and he sent it back to me and much to my surprise it started first try on the garage floor. Went through the mechanics of the swap and it ran absolutely great for FOUR years! Never left me stranded once...until two months ago. Just like someone reached over and turned the ignition off. Still had power everywhere. I immediately checked for codes - nothing. Towed it home and figured it would be a fuse or something simple. Well...that was two months ago.
I have never had such a nightmare as with this thing. Everything I check turns out fine. Power and grounds to the appropriate pins at the PCM, check. Power and ground to the coils, check. (also while cranking) No shorts to power or ground on that circuit. No spark on any cylinder.
Alldata symptom based diag process says to check VREF to the throttle position sensor. Check. Then check for RPM to display while cranking, check. Then check for Cam/Crank Sync PID while cranking. Check. Then check the ignition circuit. Done. Twice. I can take a +5v signal to the signal wire from the PCM to the coil and manually get it to spark. The PCM isn't sending the signal. OK. Maybe its the PCM. Bought a used one, PATS deleted it (verified by Forscan), crank no spark. Thought that maybe, maybe, maybe that PCM was bad. So I bought another one (luckily they are only $40 on Ebay) Swapped it in, PATS delete again. Same result.
I am 99% sure it is getting fuel (I can smell it out of the exhaust after cranking) and rail pressure reads above desired. I don't even think this matters though, because the PCM will make spark without fuel.
There are four DTC's, but they have been there for 4 years and I doubt they are going to cause this. One Ambient air temp sensor fault, one PCM Power on timer fault, one Generator current sensor fault. I've been told these are common in swaps and not something that would keep the PCM from making spark.
So I am really, really, really stuck. I have no idea where to go or what to do next. Anyone on here have ideas or things to check?
