1 Attachment(s)
Llt pop tune
Hello everyone, new to the forums.
just wondering how i can make a pop tune for the 3.6l llt, i can make it burble by disabling inj cutoff in torque management, but cant figure out what i need to change in maf calibration as the llt ecm doesnt have dfco
heres my stock tune
Attachment 155957
Lower spark values in the base tables at 15% load.
what spark tables. can you modify my stock tune file and attach it explaining what to change. as i have no base spark with a load table, only lambda. thankyou
Just in case anyone wants to know I've figured it out by messing with spark and fuel tables,
You need to change your spark tables, the 4 tables that show on the left.
The data changed on the table is on the first two columns from the rpm range 2000-6700, I retarded spark to -10?
It won't pop until your car is heated up, and wouldn't recommend doing this tune. It is mainly for the fun, if you have an exhaust and high flow cats, and if they sit lower than standard it will be ok, but with standard manifolds I wouldn't recommend as you will blow up your cats
