I swapped a 1984 LTD with a Gen 2 coyote and 6R80 Trans, only mods to the engine is a custom 4'' intake and long tube headers otherwise.
Fighting a 3-4 Shift flare at light throttle, as you apply more throttle before the shift it goes through it fine and at WOT It shifts 3-4 fine. I am not a coyote tuner by any means Ive only dealt with GM cars but I am fighting this thing I even went as far as paying a big name tuner in the coyote world and the problem persists even worse than the file I pieced together.
I have checked fluid level multiple times, changed the valve body and lead frame brand new from ford and programmed it with the ford ids tool and have reset adaptives multiple times with no help. At the point of pulling the trans to have it rebuild but wanted to give it one more swing before hand. Attached is the current file and last log of a couple part throttle shifts any help would be appreciated!
Attachment 156036Attachment 156037
