DQ250 error and tuning help?
So i connected to my 2012 TDI. Obviously cannot read the ECM but it has a DQ250 DSG and I can read that, I believe. When I try to ?read? the file this is what it says. ? If you are trying to read the TCM at the DSG plug end, please contact HPTuners support. If you are trying to read the TCM through the OBD2 port, please proceed with the stock generated file. ?
But then I can go in and make changes. Second question is where can I learn or understand what changes to make? Not much support online that I?ve seen.
