Originally Posted by
Jim P 2.0
What were you using to attempt to rom boot?
You can flash a tune into your new ecm just fine, doesn?t matter if it?s already programmed with EFILive. Every time you flash it erases the calibration in there before flashing the new one. Not sure what up to date according to witech means. If it?s got an old EFILive tune in it, it?ll have some older calibration in it. The only issue you?d likely face is the EFILive tune would likely be a CSP tune and HP Tuners won?t like that. Run risk of locking up the ecm attempting to read it on the vehicle, attempting to read it off vehicle will leave you with non functional HP Tuners file, if it is a CSP tune in there.
