1 Attachment(s)
Help With 2015 Tiguan - low throttle position and boost at high RPM
Hoping someone here can help with a problem on my wife's car. I do some tuning on LS platform stuff, but never anything on VW so I am not familiar with what is "normal". I am just trying to troubleshoot our personal vehicle; 2015 Tiguan 2.0tsi.
It just started today and she complained it has no power. She said "It is like I lost my turbo". I immediately figured that was the case.
However, I did some datalogging and found that desired boost and boost pressure follow each other, but it is limited to around 3psi. I also found that when going to full throttle the throttle position flashes up to 100% and then immediately drops down to the 20-30% range and slowly increases to around 50% at 5500rpm. Timing is 15-20 under power and fuel trim is 10% or less, so I don't feel like I have a fuel delivery issue. It seems the PCM is reducing power for some reason.
Car has no power to accelerate but will rev to 5500RPM range. It also has no CEL. Car shifts normal for the RPM, but power is just greatly reduced.
I do have a datalog I could send if anyone could help.
Any help in what direction to look is greatly appreciated! Attachment 156198
