"Hello everyone, I have a question about a table that can help or affect my SRT-4. The table in question is the following: (ECM) 36390 - Estimated Gear"
that chart is telling the ECM that "at X rpm divided by Y kph the transmission is in _____ gear."
did you change the ratios in your transmission?
No, I haven't changed anything, I'm just curious about what it's for and what would happen if it's modified.
Tanks for the quick reply
If I change the tire size, should I adjust that table? I have 26" tires (236/60/15)?
Have you changed tire size?
I run 235/60/15 tire (on 4) but not know if have to change enything or only over think the stuff.
Tanks,i dont think edit that but only curiosity, :)
We can use the nv ratio, or estimated gear, for boost by gear.
