2 Attachment(s)
tune help 04 cobra
for some reason when i try to get into boost around 3k or straight into WOT it either boosts cuts or ignition cuts. idk somethings off. been fighting it for awhile.
i was wondering if someone could help out and guide me? its driving me nuts..
ive attached the tune in question and a datalog.
afr has been stable @ 11.7 in WOT
current mods:
Return style FORE fuel system set at 40psi
siemens 80lb injectors
2.3 whipple 3.5 pulley 4lb lower
crower stage 3 cams
diamond pistons 10.5:1cr
93 pump
Ram JLT intake VMP slot style MAF w/ 100mm Maf housing
plugs gapped @.32
Did you find the issue? I've got one that part throttle around 3000 rpm I get a huge break up. If you let out of it slightly it cleans up. if you go to 1/2 to WOT it runs great
