1 Attachment(s)
New tuner here - 2016 Tahoe stock / 1st tune
Hello and thank you all in advance! I have read through countless threads on here and watched many of the videos some of you have shared links for. I have a stock 2016 Tahoe with 5.3L and 6 speed trans. I know without question I want to disable DoD, I have that much figured out. Besides that, all I am after is a more responsive pedal, crisper shifts, and maybe lessen that 'hunting for the right gear' situation. I am attaching my tune here and I have all my notes listed here. I guess what I'm asking is do my tune changes align with my goals? I am changing anything that I will regret later? I am changing anything that will shorten the life of the transmission. Thanks in advance!
2016 Tahoe 5.3L HP Tuner Changes
? Engine:
o Power Enrich Delay RPM ; Dropped from 5000 to 4000 rpm
o Power Enrich Enable Torque ; Dropped from 60 to 50% entire table
o Power Enrich Enable Pedal ; Dropped from 89 to 65 entire table
o DoD ? Was enabled, now Disabled
o Torque Management; Driver Demand Map A ; Normal: Increased values 5% for Pedal Position 16 thru 62% only across entire table
? Trans:
o Used Tire/Gear wizard to input current size tires-Changed various settings throughout
o Torque Converter; General; TCC Pressure; Desired Pressure ? upped entire table by 5%
o Use DoD Slip: Disable (DoD is already disabled, but did this for extra confidence)
o Torque Converter; Apply/Release:
Normal Apply ; 318 entire table for 1st, 2nd, 3rd
Normal Release ; 315 entire table for 1st, 2nd, 3rd
Pattern A Apply ; 318 entire table for 1st, 2nd, 3rd
Pattern A Release ; 315 entire table for 1st, 2nd, 3rd
