VE only tune and Barometric pressure
I am trying to find a way to run a VE only Tune that updates Barometric Pressure when changing elevation. This is for a P01 ecm.
My current configuration has the standard gen3 MAP sensor.
The MAF sensor is dissabled.
I have removed the narrow band O2s.
I am running the VE enhanced OS.
I have found that if I enable the MAF sensor with the VE enhanced OS it will update the barometric pressure as I change elevation. If I disable the MAF it will not update the Baro pressure.
I have searched and searched but it seams there is not very much info on how these ecms update baro pressure, I have read that they update on key on engine off, or when running and at full throttle. I would really appreciate any information relating to how the Baro pressure is calculated on these ecms.
