2 Attachment(s)
Initial Baseline - High RPM
All -
I was able to connect to our car last week for the first time with HPT to start it and get a baseline for how it starts/runs. It's a LS Swap, stock components 5.7 with a Magnuson 2300 blower kit added on it which ran in the corvette a while ago. I have several things we need to tune but I'm trying to keep it basic and take it slow as I got overwhelmed quickly with the layers trims which can change fueling/spark.
I'd appreciate initial thoughts on how to control the RPMs directly after start as it goes to almost 2K RPM, which isn't ideal when Oil isn't fully through the engine. if this log isn't detailed enough, what PIDs would you add to investigate what is running up the RPM? whether the car is 70 or 180 degrees it behaves the same way on startup.
I won't bore you with the long voyage I went through to slow it down with idle settings and removing trims to see what can be done and learning along the way. I was able to get the RPMs down but it was too low to maintain oil pressure and couldn't raise it again, then I ran out of time...I would love to settle it down first so we're not panicked and can make small changes along the way!
Thank you in advance for the thoughts.
Tim
Attachment 156970
Attachment 156973
