2 Attachment(s)
Turbo 5.3 4L80 Swap encounter Knock Sensor Low Circut Issues
LM7 5.3 Swapped 66Nova
GT45 Turbo, 4L80E w/Ford 9" 3.00 gears
91 Octane, OEM GM L96 50 lb injectors with Blind squirrels GEN4 injector data
Frozen Boost A2W intercooler
P59 HPTuners 2Bar SD MOD ECU (ECU is same one from engine vehicle donor)
Stock front O2 sensors are still in use
Innovate LM-2 Wideband
DBW Throttle with deleted MAF, IAT sensor relocated in truck manifold
OEM ACDelco Truck 19418810 2BAR Map (Purchased from Summit Racing new)
Adjustable FPR vacuum referenced (unplugged reference base is 58PSI)
2600 lb street car
I had a previous thread: https://forum.hptuners.com/showthrea...ity-2BAR/page4 and got a lot of help dialing in a drivable tune. Well, I now have a 4L80 swapped in and wired up and all is well. I cleaned up some of the tune over the last few months, but still have to dial in things and am now getting into tuning in boost and keep having the same issue.
Trouble Codes:
P0102 - Mass or Volume Air Flow A Circuit Low (Pending, Current) - From Speed Density
P0103 - Mass or Volume Air Flow A Circuit High (Pending, Current) - From Speed Density
P0327 - Knock Sensor 1 Circuit Low (Bank1) (Pending, Current)
P0332 - Knock Sensor 2 Circuit Low (Bank 2) (Pending, Current)
When I went through the motor, I installed a new Knock Sensor Harness and Knock Sensors from Dorman and this problem occurred. I checked the resistance with a Fluke 87V and then tested the pick up of knock with the hammer test and all seemed fine, but the codes kept coming back. It is throwing the car into REP mode, or LIMP mode.
I then decided to go to DELPHI Sensors, and a relocation kit to try and see if the sensors/harness was my original issue. Picked up DELPH sensors from Rock Auto, installed ICT knock sensor relocation mounts and Torqued the Knock Sensors to OEM Specs. 15 ft LBS.
Problems still exist/persist. I am conservative on my timing and not seeing any knock, just wondering if anyone has any suggestions or can see anything glaring?
Thanks.
Attachment 157027
Attachment 157028
