1 Attachment(s)
E40 07 Colorado swap Segment OS needed
I have a 07 Colorado with a 05 5.3l swap. with 08 Yukon intake and throttle body E40, t42 and harness out of a 06 GTO. Got it all running but pedal won't work. Pedal is from 06 Trailblazer 4.3l. Current performance web states that I will need to segment swap to a Trailblazer with a 5.3l to get pedal to work properly. I have been searching everywhere to get the correct OS for a segment swap. I have found a match for the ECM but not the TCM. I even tried to remove the TCM controller and with the same OS the segment swap is still greyed out. I also ordered a Trailblazer TCM hoping to find a matching TCM OS with no luck. Also downloaded dozens of tunes from the Repository.
Have been using HPT for about 3 years with several swaps and tunes under my belt but never messed with the E40. Is this some issue with this ECM in general. E40's are running over $350 on Ebay so I don't want to order a bunch to try to find a correct one.
ECM 12603159
Trailblazer TCM 24239036
GTO TCM 12590424
I have double and triple checked all wiring from pedal to TB.
