Dumb quick question about prolink, mpvi2+ and analog inputs/common ground
Hi all. Setup is an mpvi2+, the prolink cable and using two different analog inputs on the prolink cable. I'll have two autometer sensors, and electric oil pressure gauge and a wideband o2. Each gauge has datalogging output, analog signal and ground. There's only one ground on the MPVI cable, so I'm assuming I'll be using a common ground between the two gauge datalogging outputs but just wanted to check. Told you it was a dumb question.
Chris
