1 Attachment(s)
2001 Coyote swap tuning issues.
Hey guys, I have a turbo gen 3 coyote swapped Bullitt being tuned and I?m running into some issues.
It first started with codes P0012 and P0022 (bank 1 and bank 2 cam over retarded) and Fuel trims not working. Tuner said it was something in the wiring.
I took it back apart to check cam timing and pretty much went through the timing process to make sure the cams were in time. Everything was good on that.
Went through the wiring several times and didn?t see anything. Sent ecu back to pbh to be reflashed.
I decided to do a cam relearn to see if that would do anything. Couldn?t get that to work with hp tuners or sct.
Tuner sends me a ?relearn file? to get the crank relearn to work. I load the tune and everything starts working.
As soon as he starts sending tune files, the same thing starts happening. Any help is greatly appreciated!
Here is an idle log Attachment 157485
