3 Attachment(s)
INput needed for my tune. Im new to this but diving head first
Good Evening Guys, I am new to HPtuners.
I just finished rebuilding my 2004 2500hd engine. I did a stock rebuild with the exception of porting the heads and adding a cam and springs.
The Cam is a BTR stage 2 truck cam. Specs on it are 212/218 .553/.553 111LSA. the rest of the engine is stock specs, I hand ported the heads mostly just smoothing the chambers and polishing the castings up inside to flow smoother.
I used my stock file to modify and have only changed a few things to help idle. (bumped timing in the idle ranges up to 25 degrees and changed the base idle airflow to around 12-13) its idleing pretty good now and i can drive it around and it seems to do good. Can yall please look my tune over and my data log to tell me where i can improve? My LTFT look high and off to me esspecialy when im getting on it at mid to high rpms.
