replace a 09 and down e38 ecm with a 09 and up one?
so I've seen some references in posts about someone doing this. but I can't find their original posts.
I have a 08 e38 ecm, it seems the o2 offset tables used to help idle richer with a bigger cam do not work in this year/code ecm(mine, I've put test numbers and nothing). but they seem to work in the newer one watching tuning stuff. along with the other changes that might come in handy one day.
does anyone know what all goes into the swap? is it a 09 and up or 2010 ecm? does it need to come from the same car? like should I look for the 09/10 year corvette ecm?
would it be plug and play? use hpt to change vin and start tuning? or would I need to flash it with the oem gm update thru the acdelco website for 45$? I have access to that if needed.
guess I'm looking for the details of what hardware I need, and if pin outs change.
thanks. I'm searched a lot and all I see is how different they are. don't see much about swapping from one to another.
