Originally Posted by
NebulaGale
It sounds like the update caused some major issues with your system. Have you tried rolling back to a previous stable version before the update? If not, you might want to check if there’s a way to revert the changes. Also, did you recheck all your settings and files after the update? Sometimes, updates reset certain configurations. If your emissions list is mostly blank, it could be a compatibility issue. If you haven’t already, contacting support or checking if others have had similar problems with this update might be a good next step.
