1 Attachment(s)
multiple MAF related codes - troubleshooting tips?
Hi All,
I have a l86 tahoe here, struggling with the multifunciton sensor in the intake pipe. Codes are as follows:
0x7E8: P0097 - Intake Air Temperature Sensor 2 Circuit Low (Permanent)
0x7E8: P00C7 - Intake Air Pressure Measurement System - Multiple Sensor Correlation (SES, Pending, History)
0x7E8: P00F4 - Humidity Sensor Circuit Low (Permanent)
0x7E8: P0113 - Intake Air Temperature Sensor 1 Circuit High (Pending)
0x7E8: P2227 - Barometric Pressure (BARO) Sensor Performance (SES, Pending, Permanent, History)
0x7E8: P2228 - Barometric Pressure (BARO) Sensor Circuit Low Voltage (Pending, Permanent)
Vehicle was driving great - but oil pressure gauge dropped to zero, and dash said shut off engine -- check
Noted that the oil was 1.5 qt low. Topped off and restarted
Gauge still zero - but no noise etc.
Checked codes and the above were active.
After several hours of chasing 5v reference signals around etc, looking through diagrams and troubleshooting. -- every wire harness is intact, not wear in the harnesses etc. THe oil pressure gauge came back, and the vehicle still runs great, although, when it throws the codes above (intermittent) -- it will have an idle pop misfire.
I've checked the TSB's related -- fuel composition sensor plug -- cam sensor jumper harness -- AC pressure sensor -- etc. Cant figure this one out.
Truck was cammed - a month ago, and had no issues until this. PCV is temporarily venting to atmosphere while a catch can comes.
Log below, not sure it will be much help
Thx.
Attachment 159209
