Setting injector control tables for return style fuel system with vacuum fpr 99 ls1 f
Hello all. Im upgrading to a return style fuel system in my 99 SS . I like the idea of having engine vacuum control fuel delivery needs with the adjustable fuel psi regulator rather than the not so accurate injector data in the tune. Anyway, what parameters do I need to change in hp tuners injector control settings ? I already flatlined my injector flow rate vs kpa to 42.1 across the board 0-80 according to the FIC injector data card. Is there anything else ? Want to make sure I do this correctly. Thank you
