needing 2006 silverado truck norris cam tune file pdf after market heads upgreaded springs,lifters long tubes built 4l60
You looking for a free handout or for someone to tune it for you?
Lmao No just help I'm a Mechanic just Late to the tuning Aspect but with all my changes I've went ahead and took the step and got The software hp tuners and Not good with computers so I'm working on posting a log file
What heads and whats compression ratio?
What fuel?
what torque converter?
Tire size and gear ratio?
Your oxygen sensors arent doing oxygen sensor things.
B2 must be unplugged or doesnt have power.
Fuel trims are maxed out.
What injectors?
Trans temp is mighty high as well.
706 Poor and polished stock inj aem wide band 2800 b&m converter 94oct 245/70\17 30.5 Not sure on the gearing it has the G80
They are aftermarket heads or 706 heads?
706 gasket matched
Stock values
Do you have the Passenger side oxygen sensor removed?
It took almost 5 minutes for your Driver side oxygen sensor to start working.
Fuel trims are crazy.
Have you checked fuel pressure?
No I'm in the process of changing the passenger side I was thinking that was asking up to note in my scanner In texas I have good pressure
I do have long tube headers so I'm only running 2 02 sensors and a wide band
About what you'd expect, from somebody posting tuning/vehicle-specific questions in the off-topic lounge.
