As the title suggests I get a stumble an surge on light throttle tip in. As throttle is applied the TPS voltage will drop a bit and stumbles and will surge a bit after letting off.
15:17 in the log is were its noticeable. Idle in drive at .25 volts, apply a little throttle it will drop to .22 and stumble... wide band stays pretty consistent around 14.2
Suggestions appreciated!
Attachment 159707
Attachment 159708
