i have a 2014 chevy ss sedan and was looking to swap the converter to a 3000 single. What (if any) will i need to change in the trans tune? Or can i leave it the way it is?Attachment 159790 thanks for looking
I have made some of the more important changes. Misfire detection was disabled already. The next step will be to lower shift speeds, the bluecat tool should do a good job. Wouldnt recommend lockup at wot in any gear.
Thank you sir. Now all i need is the converter
All you need is not mapped in HPT, so leave it the way it is...
1. Converter K-Factor vs Speed Ratio (3 tables)
2. Converter Torque Ratio vs Speed Ratio (2 tables)
3. Converter Clutch Pressure (2 tables)
I just cant get mine to stay locked with the a/c on. It surges up and down. More when at lower speeds.
thank you for that information
