2 Attachment(s)
6L80 Put Itself in Park at 70MPH
Since adding TU/TD to my swap, I have had a transmission gremlin show up intermittently and nearly blow my 6L80 to shreds.
I followed this thread to add TU/TD to my 6L80 through pin 7 of the transmission plug: https://forum.hptuners.com/showthrea...p-shift-no-BCM
Everything was working perfectly until I went to drive on the freeway. All of a sudden, about 15 minutes up the highway on an incline, I lose drive and the RPMs drop. Next, the RPMs shoot up as the trans started selecting whatever gear it felt it wanted to.
I pull over and check the log, and even though the selector was in D6, 'Transmission current gear' went into Park, then Neutral, then 3, then 1 (between 11:51:30 and 11:51:33 of the attached log). Immediately after the hiccup, 'Trans Shift Mode' started reading 'TUTD WOT' and PRNDL Status was 'Invalid' despite the selector remaining in D6 the entire time this was happening. No matter which detent was selected, 'Invalid' remained.
EDIT: I also checked the TUTD WOT tables, which may be causing this problem. In the speed table, I currently have all upshifts set for 300MPH and all downshifts set for 0MPH. I did this to prevent TUTD mode from shifting up or down at all depending on vehicle speed, which I don't want. Can anyone confirm my reasoning here? I may have it backwards. Still, I'm not sure that this would be the cause of the transmission randomly showing 'Park' for a second while in D6, especially when TUTD is only active in the D5 range AND requires a request to activate.
I was able to get home by going into the tune and changing TUTD to 'Disabled'. It hasn't acted up since, but now I'm hesitant to reenable it for further diagnosis in fear of the transmission putting itself in Park while going 70mph again.
Anyone have any ideas as to where I should look first?
Attachment 160048
Attachment 160049
