2 Attachment(s)
Stock injectors on 2006 tahoe chev 5.3 swap
Hey guys , working on this swap it was sent for a vatts delete , rear 02 sensors delete .. used to have a cable throttle with a p01 pcm from a 2001 yukon 5.3 , client asked us to install a electronic throttle so we mounted a new harness with a p59 pcm from a tahoe 5.3 flex fuel ... it already had some 12580681 injectors I knew it needed a conversion for gen 3 so I grabbed a excel spreadsheet that was posted in the forum injector duty cycle would stay stuck at 30% in wot so the car pretty much wouldnt accelerate over 40% tps , tried to adjust the flow rate , pulses, etc. and it still wouldnt go over 30-35% inj duty cicle...
So I had some denso 25326903 injectors and installed them which I know those injectors are for a 2006 tahoe 5.3 ,, came back and returned all my injector control parameters to original values , pretty much everything is at stock values besides from my idle airflows since it has a stage 1 cam .... heres a log and the tune st fuel trims look kinda normal but still having issues turning on unless i press the pedal im chasing my tail on this one.
Attachment 160163
Attachment 160164
