3 Attachment(s)
08 c6 z06 with a&a v3 ti.
I've got an 08 c6 z06 with a built 402, and an a&a v3 ti kit. I've been working with a tuner remotely on the vehicle. He seems to be struggling with the wide open throttle part of the tune. When the car gets above 5000 rpm or so especially in third and fourth gear the car is surging in and out of power and sort of falling on its face. He has made several revisions, but none of them have really made any change. The rest of the tune seems to be pretty good. Other than a little surge at cruise at low rpm. I've attached a couple logs, and the current tune file.
Attachment 160942
Attachment 160943
Attachment 160944
Mods include:
402 cubic inch rotating assembly
240/242 Dur., 116+4, .625/.605 camshaft
CNC ported 317 heads
10.5 to 1 static compression ratio.
Msd Atomic intake manifold
Nick Williams 103 throttle body
BR7EF plugs gapped to .025
80lb injectors from A&A
Return fuel system with 525lph in-tank pump and 1to1 rise pressure regulator set to 58psi base pressure
Innovators west 8 rib pulley drive with 3.6 blower pulley
A&A v3ti supercharger
C6 zr1 map sensor.
2" primary tube long tube headers
Borla 3" exhaust
